In this tutorial we will show that Melange allows to execute Transformation on multiple Languages.
Java
Have a look in the Family of FSMs example, we have the prettyPrint() Transformation in Java that prints the content of a StateMachine.
PrettyPrintFsm.java
package finitestatemachines;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import family.StandaloneSetup;
import family.flatfsmmt.fsm.StateMachine;
public class PrettyPrintFsm {
public static void prettyPrint(StateMachine fsm) {
System.out.println("Printing " + fsm.getName());
fsm.getStates().forEach(s -> {
System.out.println("State " + s.getName());
s.getIncoming().forEach(t ->
System.out.println(
"\tIncoming "+ t.getName()
+ " from " + t.getSource().getName()));
s.getOutgoing().forEach(t ->
System.out.println("\tOutgoing " + t.getName()
+ " to " + t.getTarget().getName()));
System.out.println();
public static void main(String[] args) {
StandaloneSetup.doSetup();
ResourceSet rs = new ResourceSetImpl();
List models = new ArrayList<>();
models.add("melange:/file/input/dummie.xmi?mt=family.FlatFsmMT");
models.add("melange:/file/input/timeddummie.xmi?mt=family.FlatFsmMT");
models.add("melange:/file/input/compositedummie.xmi?mt=family.FlatFsmMT");
models.add("melange:/file/input/timedcompositedummie.xmi?mt=family.FlatFsmMT");
for (String uri : models) {
Resource res = rs.getResource(URI.createURI(uri), true);
StateMachine root = (StateMachine) res.getContents().get(0);
// Polymorphic invokation of prettyPrint()
prettyPrint(root);
The FSM manipulated by the prettyPrint() Transformation is from the ModelType FlatFsmMT
We load 4 models conforms two 4 differents Languages, all subtypes of FlatFsmMT.
So all theses models are manipulable by the prettyPrint() Transformation.
prettyPrint(root);
ATL
The Family of FSMs example contains also a Transformation in ATL that flatten a composite FSM.
FlattenFsm.atl
-- Directly adapted from http://docatlanmod.emn.fr/Models_2012/ATLstates.atl
-- @path FlatFsm=/fr.inria.diverse.examples.fsm.metamodel/model/fsm.ecore
-- @path CompositeFsmMT=/FsmFamily/model-gen/CompositeFsmMT.ecore
module FlattenFsm;
create OUT : FlatFsm from IN : CompositeFsmMT;
rule SM2SM {
from sm1 : CompositeFsmMT!StateMachine
to sm2 : FlatFsm!StateMachine
rule State2State {
from rs1 : CompositeFsmMT!State (
not rs1.oclIsTypeOf(CompositeFsmMT!InitialState) and
not rs1.oclIsTypeOf(CompositeFsmMT!CompositeState) and
not rs1.oclIsTypeOf(CompositeFsmMT!FinalState)
to rs2 : FlatFsm!State (
name <- rs1.name,
stateMachine <- rs1.stateMachine
-- Initial states of composite states become regular states in the flattened SM
rule Initial2State {
from is1 : CompositeFsmMT!InitialState (
not is1.parentState.oclIsUndefined()
to is2 : FlatFsm!State (
stateMachine <- is1.stateMachine,
name <- is1.name
-- Initial states are still initial states in the flattened SM
rule Initial2Initial {
to is2 : FlatFsm!InitialState (
name <- is1.name
-- Final states of composite states become regular states in the flattened SM
rule Final2State {
from fs1 : CompositeFsmMT!FinalState (
not fs1.parentState.oclIsUndefined()
to fs2 : FlatFsm!State (
stateMachine <- fs1.stateMachine, name <- fs1.name
-- Final states are still final states in the flattened SM
rule Final2Final {
to fs2 : FlatFsm!FinalState (
-- Transitions between two non-composite states are mapped one-to-one
rule T2TA {
from t1 : CompositeFsmMT!Transition (
not t1.source.oclIsTypeOf(CompositeFsmMT!CompositeState) and
not t1.target.oclIsTypeOf(CompositeFsmMT!CompositeState)
to t2 : FlatFsm!Transition (
name <- t1.name,
stateMachine <- t1.stateMachine,
source <- t1.source,
target <- t1.target
-- This rule resolves a transition originating from a composite state
rule T2TB {
from t1 : CompositeFsmMT!Transition,
src : CompositeFsmMT!CompositeState,
trg : CompositeFsmMT!State,
c : CompositeFsmMT!State (
t1.source = src and
t1.target = trg and
c.parentState = src and
not trg.oclIsTypeOf(CompositeFsmMT!CompositeState)
name <- t1.name,
source <- c,
target <- trg
-- This rule resolves a transition ending in a composite state
rule T2TC {
src : CompositeFsmMT!State,
trg : CompositeFsmMT!CompositeState,
c : CompositeFsmMT!InitialState (
t1.source = src and
t1.target = trg and
c.parentState = trg and
not src.oclIsTypeOf(CompositeFsmMT!CompositeState)
name <- t1.name,
source <- src,
target <- c
You can see that this Transformation manipulates a CompositeFsmMT
FlattenFsmATL.java contains the code to call the ATL Transformation.
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.util.HashMap;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModel;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFReferenceModel;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
public class FlattenFsmATL {
public static void runATL(String inputURI, String outputURI) {
try {
ILauncher transformationLauncher = new EMFVMLauncher();
ModelFactory modelFactory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IExtractor extractor = new EMFExtractor();
IReferenceModel cfsmmt = modelFactory.newReferenceModel();
injector.inject(cfsmmt, "http://compositefsmmt/");
IReferenceModel ffsm = modelFactory.newReferenceModel();
injector.inject(ffsm, "http://fsm/");
IModel inModel = modelFactory.newModel(cfsmmt);
injector.inject(inModel, inputURI);
IModel outModel = modelFactory.newModel(ffsm);
transformationLauncher.initialize(new HashMap<string,object>());
transformationLauncher.addInModel(inModel, "IN", "CompositeFsmMT");
transformationLauncher.addOutModel(outModel, "OUT", "FlatFsm");
transformationLauncher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(), new HashMap<string,object>(),
new FileInputStream("../FsmFamily/src/finitestatemachines/FlattenFsm.asm"));
extractor.extract(outModel, "output/" + outputURI);
EMFModelFactory emfModelFactory = (EMFModelFactory) modelFactory;
emfModelFactory.unload((EMFModel) inModel);
emfModelFactory.unload((EMFModel) outModel);
emfModelFactory.unload((EMFReferenceModel) cfsmmt);
emfModelFactory.unload((EMFReferenceModel) ffsm);
} catch (ATLCoreException e) {
e.printStackTrace();
} catch (FileNotFoundException e) {
EPackage.Registry.INSTANCE.put(family.compositefsmmt.fsm.FsmPackage.eNS_URI,
family.compositefsmmt.fsm.FsmPackage.eINSTANCE);
family.StandaloneSetup.doSetup();
// Polymorphic ATL invocation
System.out.println("runATL:\n");
runATL("melange:/file/input/compositedummie.xmi?mt=family.CompositeFsmMT",
"OutputATLFsm.fsm");
</string,object></string,object>
At the end we load a CompositeFsm but we cast it to CompositeFsmMT (its exactType)
QVTo
Melange supports also QVTo Transformations as you can see in the SimpleFsmQVTo example.
DummyInvert.qvto
modeltype FsmMT uses 'http://fsmmt/';
modeltype Fsm uses 'http://fsm/';
transformation dummyInvert(in inFsm : FsmMT, out outFsm : Fsm);
main() {
inFsm.rootObjects()[FsmMT::FSM] -> map mapFSM();
mapping FsmMT::FSM::mapFSM() : Fsm::FSM {
ownedState := self.ownedState -> map mapState();
initialState := self.finalState -> first().map mapState();
finalState := self.initialState.map mapState();
mapping FsmMT::State::mapState() : Fsm::State {
name := "Inverted" + self.name;
outgoingTransition := self.incomingTransition -> map mapTransition();
mapping FsmMT::Transition::mapTransition() : Fsm::Transition {
input := "Inverted" + self.input;
output := "Inverted" + self.output;
target := self.source.map mapState();
Sources
For Java & ATL
- fr.inria.diverse.examples.fsm.metamodel
- fr.inria.diverse.examples.fsm.metamodel.composite
- fr.inria.diverse.examples.fsm.metamodel.timed
- fr.inria.diverse.examples.fsm.metamodel.timedComposite
- FsmFamily
- FsmFamilySemantics
- SimpleFsmATL
For QVTo
