Showing how to solve the EP in Melange. A (possible) solution to the usual example:
// Base expression language
language BaseExpr {
syntax "BaseExpr.ecore" // abstract Expr from which Lit/Add inherit
with EvaluateLit // weaving eval() : int on Lit
with EvaluateAdd // weaving eval() : int on Add
// New variant
language ExprWithSub inherits BaseExpr {
syntax "Sub.ecore" // will be merged with BaseExpr.ecore to add Sub
// New operation
language ExprWithPrettyPrint inherits BaseExpr {
with PrintLit // weaving print() : String on Lit
with PrintAdd // weaving print() : String on Add
// All variants, all operations
language AllExpr inherits ExprWithSub, ExprWithPrettyPrint {
// Les deux inherits nous donnent Expr/Lit/Add/Sub
// avec print() et eval() sur Lit et Add, mais rien sur Sub
// donc:
with EvalSub
with PrintSub
TODO: See how Melange could also handle the Expression Families Problem.
