The Family of FSMs example is based on a set of close languages defining an FSM.
We show in this example that Melange are able to deal with the the variations in the abstract syntax and the semantic, such as composite state or simultaneous execution.
FSM.melange
package family
language FlatFsm {
	syntax "platform:/resource/fr.inria.diverse.examples.fsm.metamodel/model/fsm.ecore"
	with semantics.flat.StateMachineAspect
	with semantics.flat.StateAspect
	exactType FlatFsmMT
language FlatFsmSimultaneous {
	with semantics.flat.simultaneous.StateMachineAspect
	with semantics.flat.simultaneous.StateAspect
	exactType FlatFsmSimultaneousMT
language TimedFsm {
	syntax "platform:/resource/fr.inria.diverse.examples.fsm.metamodel.timed/model/fsm.ecore"
	with semantics.timed.StateMachineAspect
	with semantics.timed.StateAspect
	with semantics.timed.TransitionAspect
	exactType TimedFsmMT
language TimedFsmSimultaneous {
	with semantics.timed.simultaneous.StateMachineAspect
	with semantics.timed.simultaneous.StateAspect
	with semantics.timed.simultaneous.TransitionAspect
	exactType TimedFsmSimultaneousMT
language CompositeFsm {
	syntax "platform:/resource/fr.inria.diverse.examples.fsm.metamodel.composite/model/fsm.ecore"
	with semantics.composite.StateMachineAspect
	with semantics.composite.StateAspect
	exactType CompositeFsmMT
language CompositeFsmSimultaneous {
	with semantics.composite.simultaneous.StateMachineAspect
	with semantics.composite.simultaneous.StateAspect
	exactType CompositeFsmSimultaneousMT
language TimedCompositeFsm {
	syntax "platform:/resource/fr.inria.diverse.examples.fsm.metamodel.timedComposite/model/fsm.ecore"
	with semantics.timedcomposite.StateMachineAspect
	with semantics.timedcomposite.StateAspect
	with semantics.timedcomposite.TransitionAspect
	exactType TimedCompositeFsmMT
language TimedCompositeFsmSimultaneous {
	with semantics.timedcomposite.simultaneous.StateMachineAspect
	with semantics.timedcomposite.simultaneous.StateAspect
	with semantics.timedcomposite.simultaneous.TransitionAspect
	exactType TimedCompositeFsmSimultaneousMT
ExecuteFsm.java
package finitestatemachines;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import semantics.common.Context;
import family.StandaloneSetup;
import family.flatfsmmt.fsm.StateMachine;
public class ExecuteFsm {
	public static void execute(StateMachine fsm, String input, String output) {
		Context c = new Context(input);
		// Dynamic dispatch on the appropriate eval() implementation
		fsm.eval(c, output);
	public static void main(String[] args) {
		StandaloneSetup.doSetup();
		ResourceSet rs = new ResourceSetImpl();
		List models = new ArrayList<>();
		models.add("melange:/file/input/dummie.xmi?mt=family.FlatFsmMT");
		models.add("melange:/file/input/timeddummie.xmi?mt=family.FlatFsmMT");
		models.add("melange:/file/input/compositedummie.xmi?mt=family.FlatFsmMT");
		models.add("melange:/file/input/timedcompositedummie.xmi?mt=family.FlatFsmMT");
		int i = 0;
		for (String uri : models) {
			Resource res = rs.getResource(URI.createURI(uri), true);
			StateMachine root = (StateMachine) res.getContents().get(0);
			// Polymorphic invokation of execute()
			execute(root, "{x;y;z,o;p;q}", "output-" + ++i + ".pdf");
Sources
(clone the git repo https://github.com/diverse-project/melange-examples and import the following projects)
